S&S / Nikon D200/300 users
Started by craig nelson ·
  • 9Posts
  • 9Replies
  1. Hi all
    just a quick one
    is anyone or has anyone found that they can cram a d300 into a Sea & Sea DX200 housing ?
    just wondering if its possible
    regards
    craig
  2. yes, I believe Bonnie did this, do some searches, I believe she posted about it on wetpixel.
    Scott
  3. Hi all
    just a quick one
    regards
    craig
    Hi,
    I am working on S&S d200 housing right now but, having problem. It is not like Nexus
    or Subal housing. I've done new base plate & camera seat properly inside housing & lenses
    are centered. On/off switch & front dial works fine. On back cover, left side control is VERY
    difficult to make it work. Back window is small you cannot see full screen. backdial will work.
    Which means, You can do;
    On/Off
    Change EV compensation
    ISO change
    Mode change
    F-stop change
    Shutter time change
    Picture Review
    c-s-m change
    You cannot do;
    Menu change during diving(you set your camera such as raw, raw+jpg before diving)
    selecting focus point (jog dial will be centered & locked)
    and you can only see 70% of lcd screen
    I will post more info when finalized.
    Sam
  4. Hi,
    On/Off
    ISO change
    Mode change
    F-stop change
    Shutter time change
    Picture Review
    c-s-m change
    You cannot do;
    Sam
    Hi Sam,
    something new about the housing for the d300?
    thank you
    Rachid
  5. Hi,
    I am traveling since & I did not have time to work on housing.
    Sam
  6. Sam,
    thanks for sharing that. Could you show pictures of modified tray?
    Even better, will you offer one for sale?
    This should work the same for D300s I guess :)
    Andrzej
  7. I'm interested Sam! :-) Thanks for the pointer.
  8. Hi,
    After I try several times, I finally came to the point to stop the work
    & I no longer have housing. It is NOT like Nexus or Subal housing modification
    & simply S&S makes housing so tight & no extra room to play with.
    Sorry for th bad news.
    Sam
  9. Hi,
    Sam
    Ah well, I'll wait for the D400 then. Unless anyone from Sea and Sea is listening!
    Many thanks for your efforts on this Sam, we appreciate it.
