Removing Hadles from Ikelite Tray
Started by jeremyfxdwg ·
  1. I have 2 Single Handle Ikelite trays and want to make a dual handle setup for my G9. Has anyone removed the handle held on by the roll pin? if so how did you do it?
    Jeremy
  2. From the description you may need to press the pin out - post a couple of pictures and we can get more specific.
    Paul C
  3. Get some thing slightly smaller than the roll pin - a nail will do.
    File the end flat and use it to gently drive the pin out.
    Save the pin as stainless roll pins are hard to find.
