Sea&Sea Canon TTL Converter help - Canon 40D
Started by bversteegh ·
  • 12Posts
  • 12Replies
  1. Hi all -
    I'm sure I'm probably missing something simple, but just got the new Sea & Sea Canon 3 TTL Converter. Using with a S & S MDX 40D Housing, and S&S YS 110 Strobes, using a dual sync cord (ie a splitter).
    It works fine in manual mode, I can fire the strobe and control exposure with the strobe (ie syncs properly with the shutter). When I switch to TTL mode, the strobe does fire - but the TTL mode isn't working properly (everything severely underexposed). Appears to be firing out of sync with the shutter.
    Tried manual, Tv, and Sv modes. Set ISO to 100, ETTL 2 to average as recommended by S & S. Is there some other simple setting I'm missing?
    TIA
    Bruce
  2. Hi Bruce,
    I agree I'd start simple. Are you hooked up to the TTL connector on the housing? Have you tried a single sync cord from the converter to one strobe? I seem to remember I was told we'd need a seperate cord from the converter to each strobe. I don't have mine yet, the unit for the 250's isn't out. I'm guessing those two connectors on top of the converter might be a hint. Don't you love S&S manuals? You may be one of the first one to try it out.
    Good Luck,
  3. Hi Bruce,
    Good Luck,
    Well, after digging through my gear for an hour or so, I finally found my backup single sync cord (never used - shot manual last trip). TTL works perfectly single strobe/single sync cord. Don't have a second single sync cord.
    Charging up a fresh set of batteries for my strobes - I think I may have had low batteries in one strobe my first test.
  4. Hi Bruce,
    I've tried a Mk I and now own a MkIII. Although my experiences are with Nikon,
    I remember quite clearly being told one outlet to one strobe...
    I don't know why because the Matthias converters, on which these things are based,
    work well with one outlet to dual strobes. I believe that the Ike unit also allows for dual strobes...
    Anyway, with the S&S, you can use one in TTL and the other in manual as fill flash, or from the
    side for extra contrast...
    HTH,
    Bruce...
  5. ) TTL works perfectly single strobe/single sync cord.
    Cool Bruce, glad it works. So that says one needs to carry three cords with the S&S setup; the Y cord for shooting dual strobes manual, and two single cords for dual strobes using TTL converter. I was carrying a single spare cord anyway as a backup to the Y cord or if I wanted to go with one strobe. If your down to one cord you can use it as our friend from the outback suggests. :) I'm still on the fence for the converter, I'd be very interested in your thoughts on how well the new TTL converter works for you.
  6. Thanks for the help everyone.
    The converter does have 2 bulkhead connectors, so I guess I need to buy another single sync cord. I guess compared to the cost of everything else I've already bought, not that bad.......
    It's just money, right?
    Bruce - one other question though. If I did use the second strobe in manual as a fill light - will it reliably trigger with the built in slave sensor, or would I need to run a fiber optic between the strobes (in which case, I guess I could use TTL or manual on the 2nd strobe)? I have the FO cable (my backup camera is a P&S that I trigger optically) - it would just
    be nice to not have sync cords and fiber optic cables hanging everywhere......
  7. Cool Bruce, glad it works. So that says one needs to carry three cords with the S&S setup; the Y cord for shooting dual strobes manual, and two single cords for dual strobes using TTL converter. I was carrying a single spare cord anyway as a backup to the Y cord or if I wanted to go with one strobe. If your down to one cord you can use it as our friend from the outback suggests. :ninja: I'm still on the fence for the converter, I'd be very interested in your thoughts on how well the new TTL converter works for you.
    Hey Steve - I'm going to the Flower Gardens (off the coast of Texas) first weekend of August - hopefully whale sharks and mantas :P:lol: So probably won't be shooting a lot of macro to really test the converter.
    Depending on what's creatures are in the area, I'll probably fire up the 60mm for at least one dive - I'll let you know. This is my first non-Ikelite system, so I've always used TTL for macro.
    But frankly - I shot all manual on my Indo trip back in April (prior to the flood :P ) - and didn't have any problem getting exposure dialed in pretty quickly - so not sure why I dropped the additional coin for the converter - other than because it was there :)
    If you do decide to get one, I highly recommend Divervision (Joe - from Taiwan). my converter was $400, with 20 dollars shipping, arrived in 4 days. I've bought from him before, and he stands behind stuff no problem. MUCH cheaper than anywhere I could find in the states.
  8. Hi Bruce,
    From what I have read/heard, the YS110 does not reliably work with it's proprietry D-TTL, so I wouldn't bother about trying to get TTL via the F,O system.
    I think that firing any flash via the slave mode is too restrictive in your choices for the actual placement of the strobe, remembering that the flash sensor has to be within sight of and close enough to the primary flash to guarantee consistent and reliable performance.
    Personally, I use the two sync cords and there is no niggling thoughts in the back of my head...there's enough rubbish going on in there without adding to it...hehehe :ninja:
    ...Big Stevie,
    I'm not so sure that these converters are the "duck's guts..." :)
    I'm willing to bet my left b@!! that you will be less than impressed, and I'm pretty confident that you are already achieving better results with your manual settings...
    TTL's idea of 'one shot-one kill' is a nice thought, but if it was that accurate why do they offer you so many plus and minus adjustments of up to 1 full stop in both directions? Kinda defeats the purpose... :P
    BTW, nice pics from Bonnaire...
    HTH,
    Bruce...
    Edited by bruceterrill
  9. Just received an email from Sea & Sea Tech Support - they claim the latest TTL converters (I have the Canon type 3) do NOT support the dual (Y) sync cords - you need to use a separate sync cord for each strobe.
  10. You'll have a great time at the Flower Gardens - but I wouldn't be on Whale Sharks and Mantas. I have been there over 25 times and never seen a whale shark. I have seen many mantas though. I would bring a macro setup - you'll get a lot of use out of it.
    At the banks, there is not much vertical relief for WA. Think of a field of boulders. The good WA dive is the "rig."
  11. Cool Bruce, glad it works. So that says one needs to carry three cords with the S&S setup; the Y cord for shooting dual strobes manual, and two single cords for dual strobes using TTL converter. I was carrying a single spare cord anyway as a backup to the Y cord or if I wanted to go with one strobe. If your down to one cord you can use it as our friend from the outback suggests. :) I'm still on the fence for the converter, I'd be very interested in your thoughts on how well the new TTL converter works for you.
    Hey Steve -
    You probably already know this - but the TTL converters allow you to shoot manual as well (as long as your strobes have manual output control built in like the 110's or 250's- the converter doesn't control exposure in manual, just a pass through).
    And as part of my messing around, I did verify that the dual (Y) sync cord will work with the TTL controller in MANUAL only - both strobes will fire properly and in sync with the camera when the converter is in "pass through" mode.
  12. You'll have a great time at the Flower Gardens - but I wouldn't be on Whale Sharks and Mantas. I have been there over 25 times and never seen a whale shark. I have seen many mantas though. I would bring a macro setup - you'll get a lot of use out of it.
    Thanks James (I think - although you shattered my fantasy of whale sharks), guess I'll change my creature expectations a little then. Lived in Dallas for 26 years, but this my first trip to the Gardens. Hope it is a good trip - and no hurricanes in the Gulf stirring everything up :)
