Aquatica D100 w/Ports, Arm, Gears - FOR SALE!
Started by UnderWhere ·
  1. I have an Aquatica D100 housing in like new condition for sale on eBay. Here is the link to the ad:
    http://cgi.ebay.com/Aquatica-D100-Underwat...1QQcmdZViewItem
    FOR SALE: Aquatica D100 Underwater Digital Camera Housing System with Dual TTL Nikonos Strobe Ports in Excellent / Like New Condition! System includes Macro and Dome Ports, Focus Gears, Port Extensions, Strobe Arm and more!
    I have owned this housing and all accessories since originally purchased new from B&H Photo. It has been very gently used and expertly cared for. As you can see from the photos this housing and all accessories are practically like new.
    Included in the sale are the items listed in the table below. The cost for everything new was just under $4000.00 USD. This housing is compatible with the Nikon D100 digital SLR camera body and a variety of lenses when used in combination with the ports and port extensions included in this auction, please see below and Aquatica’s website for more details. The housing provides access to nearly all of the D100’s controls and allows for manual or automatic focus and zooming. The viewfinder is great and you also have full access to the LCD and menu controls. In the water the housing is slightly negatively buoyant and provides good feel and control.
    Since moving to Cincinnati, OH, I have not had much opportunity to use the housing and my photographic interests have shifted to other subjects. I am meticulous with all of my equipment and you will not be disappointed with this housing should you decide to purchase it.
    The pictures below are of the actual items being sold. I have also included a few samples of pictures taken by me with the housing to illustrate the type of results you can generate even as an amateur with this equipment.
    FEATURES:
    Bayonet Port: Positive bayonet mounting leaves no doubt that your ports are secure in place and water tight. The bayonet system dome, macro ports and extension rings, offers the fastest access to lenses for rapid changing. Allows use of lens, from a 14mm to a 200mm macro lens, in the most efficient and economical manner. Fingertip access to all key camera controls.
    Lens release for easy lens changing through the front port with camera installed.
    The most critical aspect of underwater SLR photography is the viewing system. The Aquatica D100 uses a viewfinder that derives the biggest and the brightest image possible in full frame viewing to your eye. LCD information in the camera's viewfinder is easily referenced while shooting, and chromatic aberrations have been significantly reduced for sharp focusing and exact composition.
    SPECIFICATIONS:
    Depth rating: 300ft./90 meters
    Precision cast aluminum body is fully anodized to military specifications and coated with polyurethane powder paint and clear coat.
    Accurately balanced ergonomic design; all controls are within easy reach.
    Aluminum form fitting grips are adjustable for different hand sizes.
    Size: 8 1/2 x 7 3/4 x 5 1/2 in, 21,6 x 19,7 x 11,1 cm
    Weight: 7 lbs., 3.9 kg.
    INCLUDED IN THE SALE:
    Item Description
    Part Number
    Quantity
    Aquatica D100 Underwater Camera Housing for Nikon D100 with Dual-Nikonos Strobe Connections
    D100 TTL2
    1
    Upgraded Nikonos Strobe Port Screw-In Plugs with Dual O-Ring Seals (Better Protection for Strobe Ports)
    2
    Aquatica Housing Body Port Cover to Protect Port Opening of Housing
    18789
    1
    Aquatica Moisture Alarm for Digital Camera Housing
    20023
    1
    Aquatica 8 inch Dome Port for Wide-Angle and Fisheye lenses
    18405
    1
    Aquatica 8 inch Dome Shade for Dome Port
    18482
    1
    Aquatica Neoprene Protective Cover for 8" Dome Port with Dome Shade Attached
    18503
    1
    Aquatica Neoprene Protective Cover for 8" Dome Port without Dome Shade Attached
    18500
    1
    Aquatica Dome Port Extension for Nikon 12-24mm F4 DX Lens
    18456
    1
    Aquatica Macro Port for Close-Up and Macro Lenses
    18426
    1
    Aquatica Neoprene Protective Cover for Macro Port
    18505
    1
    Aquatica Port Extension for Nikon 105mm F2.8D Lens
    18453
    1
    Aquatica Focus Gear for Nikon 105mn F2.8D Lens - Slip On Type
    18679
    1
    Aquatica Auto/Manual Focus Selector for Nikon 105mm F2.8D Lens
    18683
    1
    Aquatica Rear Protective Port Cap - Protects Rear Bayonet Mount on Ports or Extensions
    18790
    1
    Aquatica TLC 4 inch lower, 8 inch middle, 8 inch upper 3 Section Strobe Arm Including 2 Ball Clamps and Base Tightening Knob
    17501
    1
    Aquatica TLC Strobe Mount Adapter for Ikelite Strobe
    17752
    1
    Spare O-Ring Set
    1
    Hex Allen Key for Attaching Handles
    1
    Hex Allen Key for Adjusting Knobs
    1
    Manuals
    See all of it at: http://s308.photobucket.com/albums/kk350/ebayguy123/
    LENS COMPATIBILITY:
    The following lens & port combinations are supported with the equipment offered in the sale:
    Macro Port Alone:
    Nikon 60mm f2.8 D Micro-Nikkor Macro lens
    Sigma 50mm f2.8 EX Macro lens
    Macro Port with 18453 Port Extension:
    Nikon 105mm f2.8 D Micro-Nikkor Macro Lens
    Nikon 105mm f2.8 D AFS VR Lens
    8†Dome Port Alone:
    Nikon 10.5mm f2.8 G ED AF DX Fisheye
    Nikon 16mm f2.8 D AF
    Nikon 20mm f2.8 AF
    Nikon 24mm f2.8 D AF
    Nikon 28mm f2.8 D AF
    Sigma 15mm f2.8 Fisheye
    8†Dome Port with 18456 Port Extension:
    Nikon 12-24mm DX Wide-Angle
    Nikon 14mm f2.8 D ED AF
    Tokina AT-X 10-17mm f3.5-4.5 AF DX fisheye
    Sigma 10-20mm F4-5.6 EX DC HSM
    Nikon 18mm f2.8 AF
    Please consult this link before determining if your exact lens is supported in this housing: http://www.aquatica.ca/subpages/catalog/le...ikon_type_1.pdf
    Starting Bid: $2000.00, which I think is fair given the condition of the unit and everything that is included with it.
    Regards,
    UnderWhere
    a.ka. Todd
