Levels adjustment in RAW
Started by Rob Tarrant ·
  1. Is there a specific order in which we should make our level adjustments in RAW, is there steps 1-10 and if you do not use this order your photo is not so good..
    Is there a 'tried and tested' routine anyone has that works well.
    thanks
    Robert
  2. Is there a specific order in which we should make our level adjustments in RAW, is there steps 1-10 and if you do not use this order your photo is not so good..
    Hi Robert, Your in luck, one of the many hidden features of Wetpixel is the Articles section. There is an article there that describes just what your asking for if using ACR, the link is here. It was written in 2004 but I believe is still accurate. If your going to use Lightroom remember that the sequence you make the adjustments in really doesn't matter because the software makes the changes in what it thinks is the correct sequence based on what is in the side car file. Have fun!
