New Canon HF11 and HG21 AVCHD at 24mbps!
Started by Drew ·
  1. Canon Japan has announced the new HF11 and HG21 updates with the full 24mbps MXP AVCHD standard bandwidth. Since at 17mbps the picture quality is pretty much on par with the 25mbps HDV MPEG2 Long GOP standard, the new full bandwidth which takes advantage of MPEG4 compression should be noticeably better. The barely year old HF10 is updated to the HF11 with double the memory (16 to 32GB) and retains SDHC memory card. The HG10 is updated with a 120GB drive and ability to record video to SDHC. Otherwise they are pretty much the same cameras.
    At 24mbps MXP, these AVCHD camcorders are ushering in the era of memory card camcorders with the quality to match and beat the now almost 15 year old DV tape. Long live DV tape... Hail the new standard! :blink:
    Here are the Japanese web announcements:
    http://cweb.canon.jp/ivis/lineup/hivision/hf11/index.html
    http://cweb.canon.jp/ivis/lineup/hivision/hg21/index.html
  2. Drew any idea if the NLE's will be able to handle AVCHD at 24mbps or will we need to wait on an update?
    Cheers, Simon
  3. The only way you can edit that stuff is to convert it to and intermediate codec which means lots of time to convert it or to have the editing preview window set on a very low draft res.
    So much for instant editing.
  4. Simon, AVCHD 24mbps should work the same as the other speedwidths and shouldn't need an update. It should be just a bigger file using the same compression scheme. In fact, due to the larger bandwidth, it should require less CPU work.
    Wags, it's a pity you don't see the advantages of flash media based cameras. You can buy 10 32GB SDHC cards and have enough recording time for 30hrs of recording time in a package that is as small as 1 mini-DV tape. Even 40 8GB SDHC cards are not bigger than 2 tapes. That is enough, back up for you on location until you can get home. SDHC is solid state and can take even getting wet, humidity and dust better than tape. Ever drop a tape into sea water? Dead! SDHC, dried out, it retained all my shots. You can instantly throw out clips that are crap on camera( including fast cue etc) without a laptop. It allows faster dailies editing to choose clips worth keeping again in camera and instant review capability. Basically you can narrow 30 hours of clips down to a manageable 3 without a laptop on a boat and then convert with the NLE once you back from location/holiday. 3 hours of copying/converting even at 4x real-time is better than copying 30 tapes into the harddrive to find the scenes you want, not to mention having to switch tapes hourly vs copying at 10-20MB/s per card, finishing in under 1 hour.
    Sure it may not suit YOUR needs as a daily dive DVD camera, but editing isn't just about how fast the NLE can preview or playback full res in R/T. It's about working within a proper workflow that best suits the task. AVCHD at 24mbps will be better than HDV in many ways, hopefully including motion artifacting. Bear that in mind before you condemn the format.
    Edited by Drew
