I'd like some advice and feedback on the following two lens the Canon EF-S 10-22mm Wide Angle and the Tokina 10-17mm Fisheye.
I'm about to purchase either one but at the moment I'm a bit unsure which would be better for my purposes. I want a good lens for wrecks, sharks, mantas, scenery and if lucky enough whales.
The Canon is more expensive however has a greater zoom range and can be used above water without the fisheye effect, however it can't focus as closely as the Tokina but can support filters with the right port.
The Tokina is cheaper and as I understand it the fisheye effect is cancelled out underwater by the use of a dome port however it can't take filters.
The Canon apparently is the equivalent of a 16-35mm zoom for a 35mm film camera so I don't know why they call it a 10-22mm however I am not sure if the Tokina is equialent to a 10-17mm 35mm film camera either. Marketing is a pain I just want the facts when I buy things.
Also the Tokina has a macro ratio of 1:2.56 but I can't find the info for the Canon Macro ratio if it has one?
If anyone can shed some light on these issues or has personal experience with these and even examples I would much appreciate it. Please dumb it down a bit I'm still learning all this stuff.
Pete
