A Novel Idea for Underwater Photographs
Started by ATJ ·
  1. For some time I have been synchronising my dive watch with my camera so I can determine the depth at which the photographs were taken. This has worked well, but I have only partially automated the process and I still need to do a look up for each photograph. I have wanted to make it more automated but couldn't find a suitable place to stick the depth data. While looking at geotagging of photographs and GPS equipment, I realised that most GPS devices store altitude and that Exif supports altitude data. Of course, depth is essentially negative altitude so I am now tagging my photographs with the approximate latitude and longitude of the dive site along with the depth at which each photograph is taken.
    Here's a write-up in my blog: Geotagging My Dive Photographs.
  2. Interesting idea. I rarely need to know the depth of a photo, but if you do, this is pretty cool.
  3. Sounds like a cool idea. Is it just a watch you synchronize with or is it maybe a dive computer?
  4. Your ideas sound interesting.
    I have been trying to syncro my checkbook with my internal dive desire and my vacation schedule. That way, when I want to go diving, I have the cash ready to go and have the time off work.
    Not doing well enough so far to post good results.
    Since I want to go diving essentially every day, success is fleeting.
    If it gets better or I find a breakthrough, I will post it!
    dave
  5. Is it just a watch you synchronize with or is it maybe a dive computer?
    I usually synchronise it with both my dive watch and my dive computer (as described in this link: http://andrewtrevor-jones.com/divedepth.html). I most often use the data from my dive watch which I attach to the camera rig.
    Edited by herbko
  6. I usually synchronise it with both my dive watch and my dive computer (as described in this link: http://andrewtrevor-jones.com/divedepth.html). I most often use the data from my dive watch which I attach to the camera rig.
    Can a mod change my post above to move the ")" outside the URL tags? It is causing 404s.
    By the way, why can't I edit old posts?
    Edited by ATJ
  7. Can a mod change my post above to move the ")" outside the URL tags? It is causing 404s.
    OK. Fixed. You're only allowed edits for a short time after the post. Can't change history :P
  8. Thanks. :P
