Subal dome + Canon 5D
Started by Daniel P ·
  1. Hi!
    I've got a DP-FE3 subal dome but Subal recommend
    DP-SWB/3 for my Canon 17-40 on their home page, does anyone know if I can use
    DP-FE3 for Canon 17-40? if so, what extension do I need?
    /Daniel
  2. I just had a look at the Subal port recommendations for the EF17-40 / 4L USM and 5D and they are recommending a 50mm extension with the DP-FE2 dome port:
    http://www.subal.com/en/portselection/port...;markennummer=1
    As I understand it the DP-FE3 has superseded the DP-FE2 and only differs from it in having a modified bayonet mount. Here's a quote from the Reef Photo web site:
    DP-FE2 is a discontinued product, and designated the second version of Subal's universal "fisheye" dome port. DP-FE3 is the exact same piece of glass with a "third generation mount" that is slightly redesigned to work with various port adapter rings.
    Therefore, I believe the DP-FE3 with a 50mm extension will do the job.
    Edited by Gudge
  3. Yes, DP-FE3, EXR-50, and a plus +2 diopter is the best combo I've used.
  4. I second that. I use it all the time in the pool. Can't use the diopter though because I'm in and out of water, but I bet it helps.
  5. I second that. I use it all the time in the pool. Can't use the diopter though because I'm in and out of water, but I bet it helps.
    Thanks for your quick replies
    I checked Subal's home page
    and they are writing this:
    DP-FE2 + EXR50
    DP-SWB + EXR33
    (DP-SWB + EXR 40 -Full size chip)
    so if I understand this : DP-FE2 + EXR50 should be for cropped cameras
    and (DP-SWB + EXR 40 -Full size chip) for full-frame cameras
    this makes me little puzzled that you can use DP-FE2 + EXR50 on a full-frame camera, or am I missing something here?
