I have to check if the new Tokina 11-16mm zoom is even physically usable in Ikelite's 6" ports since the Tokina 10-17mm Fisheye is much more popular. (??????)
Well, the Ikelite chart indicates that one can use the 6" 5503.50, but the chart also indicates that:
(?*) This zoom lens will focus close enough that adding a + diopter close-up to the lens is NOT required, but some people feel a +2 close-up lens may enhance corner sharpness. Longer port may be required to stack filters or close-up lenses.
and that plus your next comment (in addition to the previous comments!) make it look like poor economy to use a 6" dome on the 11-16.
Tubino, if you are referring to the 6" in air question, ANY port above water is simply a clear window. It's when you try and shoot over / under shots and the underwater portion created by the dome in water looks to be 12" image distance in front of your lens, and the above water part where the actual subject physically is farther away, when the 6" radius can't provide enough depth of field to keep both in focus.
Hope this makes sense.......
Yes, that makes sense with the under/over, AND reminds me of the focus advantage of the 8" dome over the 6" underwater too.
I see that a B&W +2 diopter for the 77mm lens size is something like $55 from Reef Photo, and that's barely a razor nick compared to the money hemorrhaging I've done lately with UW photography!
On a sort of related note, today I did a goofy thing. I put my 18-200mm Nikon lens on, and used some tape (
) to fix it at around 38mm, the widest I could use with my one and only port without major vignetting. Then I took it to Maumee Bay on Lake Erie and tried some over/under shots, with f18 and up. I learned some things. I learned that the slight vertical difference of the eyepiece over the lens does NOT change the fact that you need a mask and snorkel to do this, esp. with waves breaking over you! I may learn something more significant once I look at the results on a screen.
