Thr right lense?
Started by chris j ·
Thr right lense?
  1. I have only used a canon 50 mm macro lense on my eos350d in sea & sea housing with reasonable results.Now I fancy going down the cfwa route and was considering the canon efs 10 -22 with suitable dome and diopter. Has anybody used this lense? and does it give a wide enough angle at 10mm for large critters close in? [a chance encounter with a whaleshark in sharm el shiek with the macro lense was very frustrating!!]Also is ttl control of strobes essential for cfwa as I have been mnaually exposing my shots so far,regards chris j
  2. Chris,
    At 10mm it does go pretty wide. But at 10mm, the corners get real soft (blurry). You get better results at a higher zoom and/or closing the aperture. It's a great lens for topside and I really enjoy it for landscape and group party shots, but I got tired of trying to figure out which diopter to use.
    For underwater, you might want to consider the Tokina 10-17mm fisheye. It's a versatile lens. My 10-22 has been relegated to topside only since getting the Tokina fisheye. Search for a post by Alex Mustard on his use of this lens for Close focus WA.
    As for TTL, I found the S&S TTL did OK with close focus WA but lately prefer manual (well actually I sold the TTL converter...)
  3. Chris,
    If I could figure out to attach pix to this post I have a couple of examples of cfwa with the 10-17...give me a hint and I'll post them.
    Pakman,
    How do you shoot with dual strobes without the converter? Dual sync cord or slave one strobe? I'm pretty green and headed on a liveaboard trip in a few weeks...shooting without the converter ='s one less thing to break!
    Thanks!
    Mike
  4. Chris,
  5. Chris,
    Pakman,
    In the reply box there is a an "insert image" cursor under the fonts dropdown menu,regards chris j
    Thanks!
    Mike
    Edited by chris j
  6. thanks for the advise ,which port and diopter do you use? regards chris j
