Light and Motion SR3 Sport Video Housing
Started by depelos ·
  1. I'm selling a brand new Light and Motion SR3 Sport Underwater Video Housing. Most compact camcorders fit in it. I won it in an underwater photography contest and I have never used it or put it anywhere near the water. Below are the specs from Light & Motion. Please email me for more info - depelos1@hotmail.com. I'm asking $400 obo. Retail is about $800. Buyer pays actual shipping costs - I will use USPS (with tracking) unless requested to use another method. Housing will ship from my parents' house in Virginia. Thanks!
    The Stingray III Sport is the perfect video housing for the first timer just getting his feet wet. The Sport supports a wide variety of the newer compact video cameras and simple design makes capturing underwater video images a breeze. While the Stingray III Sport is simple to use, it utilizes all the design benefits of the Stingray III including all aluminum construction, electro-magnetic controls, easy load camera tray and double O-ring seals. Housing also includes our rotating latches that give you the peace of mind to focus on your dive and the subjects you're after. As your interest and skill level grows, you can add a Monitor Back and a lighting system. The Stingray III Sport can be purchased as a solo housing or a complete Travel Package including one or two lights, charger and a custom case.
    Features:
    Ease of use
    . Fingertip electronic control over standby/record, zoom, auto-focus on/off, video/still mode, and manual focus
    . Light weight - only 5 pounds!
    . Integrates seamlessly with optional lighting systems
    Performance
    . Rugged aluminum construction throughout provides years of trouble free use
    . Optional Monitor Back docks into housing - add features as you need them
    Reliability
    . True electromagnetic controls do not penetrate the housing hull.
    . Redundant double O-ring radial bore seal system on camera loading door provides maximum protection and does not depend on clamping pressure for security.
    . Rotary Locking latches are more reliable and easier to use than clamps.
    . User swappable electronics (just in case).
    Construction
    • Pressure Hull: 6063-T6 aluminum
    • Rear Plates: 6061-T6 machined aluminum
    • Hardware: 316 Stainless Steel throughout
    • Ports: Acrylic flatport and viewfinder window
    • O-rings: Buna-70
    • Other: Various injection molded ABS, Santoprene, & Polyethylene switches, latches, etc.
    • Finish: Clear anodize
    Controls
    • True non-penetrating electro-magnetic
    • Easily removed for cleaning
    Depth Rating
    • Each housing individually tested to 150 fsw
    PRODUCT Stingray III Sport
    852-0087
    Size 9.3 l x 7.2 w x 6” h
    Weight (air w/o camera) 7.25 lbs
    Weight (h2o w/camera) .25 lbs
    Port Flat Port
    Fingertip Controls record/stand-by, zoom, memory stick / video, auto focus override, momentary auto focus, manual focus
    O-ring kit yes
