Seacam housing + S45 + Seacam-flash
Started by Joecam ·
  1. Housing and viewfinder are only used a few times and are in "like new" shape.
    The housing is build for the Nikon F90 and contains moisture alarm and double Nikonos flash.
    The port is a 60mm port (with optical coating) and extentionring for the 105mm Macro.
    Viewfinder S45 , which of course can be used with other Seacam housings.
    The S45 offers an incredibly large, bright image which is viewed at 45 degrees from the normal viewfinder position.
    The S45 can be rotated to enable vertical shooting and has many applications beyond the 'normal' as it allows for extreme low level photography and can even be used in ponds or rivers or for split shots. A serious viewfinder, but not cheap.
    The S45 is ideal for macro photographers, but is perfectly well suited to general underwater photography too. Dioptric adjustment is possible to suit each individual's eyes.
    Seacam system-flash for the SB28 with pilot light , batteries are new + charger.
    The cable is Seacam cable S6 -Nikonos fitting.
    The AF-MF switching gear + manuel focus gear for the 105AF-D macrolens.
    Photo's can be send
