Inon Z-240 and Olympus PT-E05 housing
Started by dkayuk ·
  1. Hi
    I am considering a move to the Olympus PT-E05 housing from my existing SP350/PT30 setup. Currently, I own a flashgun made by Inon - its' the Z240 Type 3 with the Inon arm system, and it's hooked up via the Inon Bayonet and a fiber optic cable. It's used in manual mode (configured as SLAVE) on my camera.
    My question is, what do I need to buy to connect my flash gun to the Olympus PT-E05 housing. I expect that the arm system doesn't need to be replaced?
    I am going with a fairly basic system for now, using the 14-42mm lens and the 35mm macro lens. The plan is to stay with full manual/SLAVE mode. Will this work?
    If anyone has this setup, I'd be interested in your experiences with it (good or bad).
    thx
    DK
    PS: does anyone know of a US reseller who will ship to the UK? I spoke to a couple of UK retailers and apparently the PT-E05 housing is not available in Europe!!
    Have looked at the B&H website but they don't seem to sell any Olympus SLR housings.
  2. PM Sent.
    You should have what you need to work with your Inon strobes. They should work great in S-TTL as well as manual. The optical cord just goes in the top "port".
    The tray necessary needs to be fairly wide and flat to fit. I know of a couple of options, but one is expensive, the other only takes one strobe... I'm actually working on getting my manufacturer to design a new one for this housing, but it will be a ways off.
    Jack
  3. The PTE-05 has two built in fiber optic ports in the housing. All you need to have to connect the Inon is a Inon optical D cable....this should be the same cable you're using. I actually added Sea&Sea optical connnectors to the open end of the D cable and they fit in the larger slots however, I believe you can just insert the cable into the smaller openings if you don't have the Sea&Sea type.
  4. The PTE-05 has two built in fiber optic ports in the housing. All you need to have to connect the Inon is a Inon optical D cable....this should be the same cable you're using. I actually added Sea&Sea optical connnectors to the open end of the D cable and they fit in the larger slots however, I believe you can just insert the cable into the smaller openings if you don't have the Sea&Sea type.
    thx for your reply Gary.
    How would the open-end of the D cable secured? Some kind of velcro or would duct-tape do the job?
    DK
