Subtronic Maxi
Started by Billb ·
Subtronic Maxi
  1. I am thinking of getting a Subtronic Maxi with iTTL for my Nikon D200. I have been using an Alpha Pro for the last 8 years, but unfortunately it has gone wrong and Subtronic say it is beyong economical repair (it made a loud bang underwater and flashed no more!).
    Since going digital underwater I have been shooting manual and would like to have iTTL for some situations as well as manual.
    Does anybody have any experinece with the Maxi and how well its iTTL works with Nikon DSLR's, the specification looks good and with the external battery pack in the arm it will help to make travel easier.
    Do you have to set the camera up in any particular way to use the flash in iTTL mode?
    In manual mode you can select 1 of 4 powers, can you also use the exposure compensation to further adjust the flash output?
    Are the exposures good or do you need to use the compensation on the flash and braket?
    I assume you can bracket aperture from the camera?
    I assume the sysnc speed will be 1/60?
    Any reliability issues with the iTTL?
    Any recomendations for a similar power flash (200joules) to the Subtronic?
    Bill
    Edited by Billb
