nikon 35mm 2.0D
Started by sharky1961 ·
nikon 35mm 2.0D
  1. Hi,
    I am interested in the nikon 35mm 2.0D for shooting fishportraits and sharks. Does anybody uses this lens and can you recommand this lens. I already own the nikon 17-35mm but I think the 35mm will make a better Bookeh and is sharper at wide open apertures. How are your experiences with this lens and will it give better results as the 17-35mm? I want to use it behind a dome because so it will give me the 35mm. Do I have to use a close up lens? closed focus distance is 25cm.
    Rob
    Edited by sharky1961
  2. Hi,
    I use this lens with the Nikon D200/D300 behind a flat port. Since the Micro Nikkor 60mm litterally becomes a 90mm with the APS-size sensor, I use the 35mm as a "quasi-micro" lens for fish portrait and some close-ups.
    Great results.
    Haven't used it behind a dome.
    Michel GIlbert
  3. Hi,
    Rob
    I'd be interested also Rob in what people have to say about this lens...John.
