I own 8 extremely good Nikkor lenses that I bought in 1970. One is a fabulous 20mm, and another is the 50mm macro, both probably suitable for underwater work. All these lenses were bought and used for decades on my Nikkormat and Nikon FTn film cameras with great results.
I am considering upgrading to a D700 from my D70. I just learned that my 1970s lenses can be converted for use with the D700 in FX mode (and if I don't mind sensor cropping, with the 700 in DX mode or the D70).
Is anyone using converted lenses like this under water with a housing? If so, any significant downsides?
I'm sure there are port size issues, and I will check closely with the housing manufacturer I select (probably Ikelite). It may not be possible to change the aperture under water, unless there is a dedicated aperture ring. I also assume there are manual focus issues, since the converted lenses will also lack autofocus functions. But it is my understanding that otherwise, the 700 can use them in aperture priority mode with all the other functions available for modern lenses.
What are the flaws in my strategy? Conversion is between $25 and $35 per lens. In return I get great glass for a song.
Thanks for any advice.
