O ring grease- ?
Started by shil ·
O ring grease- ?
  1. Hi all,
    Recently started using an Oly housing for the sp 350, reading the manual find that Oly insists using only Oly supplied grease, which they claim is special , for silicone O rings.
    Is that true ? what is special about this grease, that in case I finish this OEM supplied tube, I cannot use regular silicone grease which I use for other dive gear. It is just lube right ?
    Shil
  2. Hi all,
    Shil
    The old school guy in me says grease is grease but I only use Oly grease. I read somewhere that some greases can cause an oring to swell and distort.
  3. Hi Shil,
    Don’t use normal silicone grease on silicone o-rings.
    You can’t use silicone grease on silicone o-rings. You can use this grease on polyurethane o-rings, or other plastics, but not silicone.
    You have to use fluorosilicone grease on silicone o-rings
    A while ago I wanted to find and alternative and after a lot of researches I found out that it was my fault if I damaged some o-rings. They all swelled up. I bought fluorosilicone grease and it did work.
    Look at these sites.
    http://www.efunda.com/designstandards/orin...;SC=Sea%20Water
    http://www.camerasunderwater.info/articles/maint.html
    http://www.dowcorning.com/applications/sea...amp;country=HKG
    I ultimately advise you to use the original grease. Different housing use different plastics for the o-rings and the grease may damage them.
    alex
