Sea & Sea DX200 Housing Modification
Started by digidiverdave ·
  1. Has anyone any information or tried to use the TTL converter port into a 5 pin sync port for strobes, giving two individual sync ports instead of one?
    Looking at the motherboard it looks as though it may work by removing the excess wires and leaving the common ones (red & white) connected.
    Seems easy but usually is not ... can you help?
  2. Nope, it rally is that easy. Or you could mask off the pins other than trigger & ground on the hotshoe with electrical tape, or you could buy one of Inon's TTL Insulation Plates and drop it in to the bulkhead.
  3. Nope, it rally is that easy. Or you could mask off the pins other than trigger & ground on the hotshoe with electrical tape, or you could buy one of Inon's TTL Insulation Plates and drop it in to the bulkhead.
    Many thanks for this - You think better just to cut wires or unsolder from the motherboard? - have you carried this out on your housing? - all works well?
