Old strobes with digital SLR
Started by iZnobad ·
  1. I just switched from film to digital and am a “rookie” to this topic when it comes to interface between housing and strobes. I have kept some Ike strobes in spare. Can I use these strobes with a digital SLR (Nikon D300 in S&S MDX housing) when shooting with them in manual mode? The strobes are SS-50, SS-100 and DS125 w/slave sensor.
  2. I just switched from film to digital and am a “rookie” to this topic when it comes to interface between housing and strobes. I have kept some Ike strobes in spare. Can I use these strobes with a digital SLR (Nikon D300 in S&S MDX housing) when shooting with them in manual mode? The strobes are SS-50, SS-100 and DS125 w/slave sensor.
    Yes, It should be no problem but you need to remove pins on the hotshoe cable in the housing
    so that you only use trigger and ground. If you do this then you can only shoot manual.
    /Daniel
  3. Nikon D300 in S&S MDX housing
    If you're going to drop that kind of coin may as well buy you another DS125 to go with the first and have a completely digital system.
  4. I agree, the SS50 will only give you one power setting - full. And the SS100 will only give you two power settings.
