E410 focus problem
Started by manta ray ·
E410 focus problem
  1. HELP!
    I am leaving for Bonaire in three weeks and my E410 just stop auto focusing. Anyone ever have this problem? Help
  2. The lens and the camera "talk" to each other via a set of contacts on the lens and the camera body. You may want to try to carefully clean those contacts. Look at the menu on the rear of the camera (turn camera on and press info. button) to see if you have set the camera to manual focus. AF will not work if the camera is set to MF.
    Phil
  3. Have you sold that E410 you had?
  4. I take it you've tried several lenses. I've had lenses not seated correctly do that. I also had a battery discharged to the point where the camera didn't shut down but the lens wouldn't autofocus. Other than that, I can't think of anything other than the settings Phil discusses. As far as a replacement, you should try Ebay. Cameta Camera on their should have them factory reconditioned for reasonable prices.
