FLASH CS4 encoder
Started by wagsy ·
FLASH CS4 encoder
  1. Hi
    As most know the best way to put video onto the net now days is with FLASH.
    FLASH can do H.264 now but I have been messing around with FLASH CS4 and it's encoder and by the looks of it does a great job in encoder files. It will max out all your cores if you are using a QUAD CPU and for long encodes make sure you have a good cooler on you CPU as it will get pretty hot running at max speed.
    FLASH CS4 also has this codec called F4V now which the latest FLASH 9+ player can play and the best thing is you can add scene points to it like you can with flv but cannot with H.264.
    Anyhow here is a small 2 meg, 30 second F4V clip to show you it's quality.
    Its was rendered out as 1 pass vbr 600kbps max.
    http://www.hdvunderwater.com/test/test.html
    We were down at 100 feet (30metes) and the guy is using a HDCAM in a custom titanium housing.
    I am abit wobby as I had a dry suit on and was shooting one handed. ;)
  2. Hi
    I am abit wobby as I had a dry suit on and was shooting one handed. :guiness:
    Wags looks good, loaded real quickly also. That is some housing there ;) When I get a chance to play with it (CS4) will let you know how it works on an Octo Core Mac :P Just have not stepped through all of CS4 yet....
  3. Hi Drew
    Yeh it's only 600kbps max.
    I'll make another with with scene points, like a DVD scene selection thingy.
    Octo Core Mac...sounds funny...should be a winner. What's that going to cost you?
    I have been watching some clips on Photoshop CS4 and it has some cool new features and can use your GPU.
    I'm going to get a water cooler for mine so I can crank the 2.4 QUAD to 3.6ghz. It's amazing how easy these chips overclock.
  4. Hi Drew
    Loaded the Collection in today finally and playing about as I menitoned in another thread. So far things are working well and the Encore doing a Flash DVD is cool. Had not tried that before.
    As to the Octo Core, well it is not going to cost me anything...well sort of. I already had it ;) 8 2.8 Gig Processors with 10 Gigs of RAM, 4 Terrabytes Internal Drives, another 14 Terrabytes External.
