Nexus Housing
Started by RBernardo ·
Nexus Housing
  1. Hello forum,
    does someone knows what size is the inside screw of nexus housing's?
    thank you
    Rui
  2. Hello forum,
    thank you
    Rui
    Rui,
    Which nexus housing ? and which screw ?? I will try to answer...
    Sam
  3. Rui,
    Sam
    Rui,
    From your profile, it seems that you have a Nikon D80, so I assume that you have a Nexus D80 housing. Which model of D80? I believe there are 3 versions: The earliest w/o fiber optic port, with one fiber optic port and M5 port size, and the latest has two fiber optic ports, M6 port size and is called the D80 Master T2.
    Regards,
    Bob
  4. Hi all
    sorry for the missed info
    i have a d80 camera, in a patima housing
    i bought a d300, i have read (do not know where, thats why i am asking..) that the inside screw, to attach the several port's are the same size as patima housing
    since i have some port's of patima, and if they are of the same size as nexus, my choice it will be a nexus housing istead a subal...
    thank you all
    Rui Bernardo
  5. Hi all
    thank you all
    Rui Bernardo
    Well Sam is Mr. D200/D300 and you should await his answer. I believe that the new Nexus D300 has the M6 port size. I think that there are adapters to go from M4 (F4 Pro) to M5, so there may be adapters for M6 <->M5. Since Sam has a Patima also, may be he can resolve this issue for you.
    Regards,
    Bob
  6. Hi all
    thank you all
    Rui Bernardo
    Rui,
    Patima ports are in same diameter as Nexus M5 port BUT, pitch in thread is slightly different
    & company is not recommanding to use third party's port. however, I have been dove with Nexus
    M5 ports with my Patima housing but, could not do vise verse( it goes in very, very tightly
    which is not acceptable in underwater world).
    Nexus changed port size from M5( d200 or older model) to M6 (d300 or newer) and an adapter
    is available (I think I've seen some limitation there too).
    Sam
  7. Rui,
    Sam
    Hello Sam,
    thank you for your answer.
    you have Patima and Nexus housing, did you tried already the Patima ports in Nexus housing?, only to test the waterproofness?
    thank you
    Rui Bernardo
  8. Hello Sam,
    thank you
    Rui Bernardo
    Rui,
    I do not understand what's your point is but,
    1.I tried & found Patima port cannot be put on Nexus housing as thread size on port is different.
    2.I tested it to reduce no. of ports/volume of the equipments I bring to trip.
    Sam
    Edited by shchae
