D100 and D-TTL
Started by garoupa ·
D100 and D-TTL
  1. Hi there !
    Having used a Subal housed D100 with one housed SB 800 for a while, D-TTL has always worked very well.
    Now I'm thinking about adding a second strobe to the a.m. stuff, what do you think about addind another housed SB 800 ?
    Will the D-TTL still work with both the strobes connected ?
    (please note that the D100 is not working I-TTL, only D-TTL....)
    Your advice will be welcome.
    Best regards,
    Benoît
    France
  2. Hi,
    It has been discussed here many times & only way you can use 2xSB-800
    is connect 2nd flash to first one by using fiber-optic cable. You can DIY it or
    buy/use Fantasea SB800 housing & accessories. I have seen this working with
    even film-ttl & it should work with d-ttl too.
    Sam
