Gates Housing Fixture for Float
Started by meimei ·
  1. Can anyone suggest how I can get a more rigid fixture of the float when using the SWP?
    The float that came with the bungee is always swiveling. Is there a adaptor to sit on top of the housing so it stays put...
  2. Can anyone suggest how I can get a more rigid fixture of the float when using the SWP?
    The SWP25 now ships with a rigid bracket that will attach to the dovetail on top of the Gates HC9. The bracket holds the buoyancy tube out over the port so your buoyancy is added right where you need it.
    The tube is the same size so all you should need is the bracket.
  3. Can anyone suggest how I can get a more rigid fixture of the float when using the SWP?
    Hello Meimei,
    Please contact me by PM. We have several other options to secure flotation that you might consider.
    John
