Tokina 11-16 Aquatica zoom gear
Started by stever ·
  1. The EF-S 60 macro focus gear works for the Tokina 11-16 2.8 on my 20D in Aquatica housing. They may have changed the design of the gear, but it should still work.
    Do i need a diopter with the 8 inch dome port?
    Have 10-22 with zoom gear for good price.
  2. I use the gear for the nikon 12-24mm and it works fine. I would suggest a diopter, really helps corners at wider apertures. I use the 9.25" megadome though. Cheers,
    Chris
  3. What extenstion ring are you guys using for this lens?
    Ryan.
  4. i'm using the 18456 because i already own it for the nikon 12-24mm, but i think the 18463 would be better.
  5. with the Canon, the 18453 works, but the 18462 might be a bit better (or not, and i'm not packing another extension)
    i've also heard the +2 is a good idea with the 8 in port, so i'll add that
