Aquatica 5D Housing, Camera + Extras
Started by jodyelliott ·
  1. I finally decided I should sell my old set-up. I have used this set-up (most of the items) for 2 years. The view finder was use for a little over a year. It has been serviced and not used since June. My rig is located in Monterey, California.
    Here is what I have for sale:
    $1500.00 for Aquatica Canon 5D Housing Glass Optic Flat Port
    $2800.00 for the stuff below:
    Aquatica Magnifying Viewfinder 'Aquaview'
    8" Dome Port
    8" Dome Shade for Wide Angle
    8" Dome Shade for Fisheye Lens
    Zoom Gear for Canon 16-35mm f/2.8L Type 1 Lens
    Focus Gear for 100mm f/2.8 Macro USM
    Port Extension Ring for (A) #18700 100mm Lens
    Port Extension Ring (B) #18456 for 100mm +1.4X Teleconverter Lens
    Port Extension Ring © 18462 for 180mm
    Port Extension Ring for (E) # 18463 100mm? Lens
    Port Extension Ring for 16-35mm Type 1 Lens (Need a 2x Diopter for Lens)
    Port Extension Ring for 20mm Lens #18457?
    (15mm Fisheye Lens No Extension Ring Needed)
    Spare sync port kit
    O-Ring Kit
    Ultralight 'T' Groove Plate - Qty: 2
    Ultralight 'T' Groove Base Adapter - Qty: 2
    Also included are the following: (You can see what they look like here, http://www.xit404.com/under_water_camera_gear.htm)
    Custom Focus (Zoom Knob)
    Custom Lens Gear for 100mm focus moved to Zoom Gear spot
    Custom Body Cover for shipping
    Custom Port Cover for shipping
    $1200.00 for my Canon 5D body (If you want a 2nd body we can talk about what I would like for that one)
    $5500.00 + tax (tax may be negotiable)
    I hope some one gets the amount of use out of this set-up as I did. I loved shooting with the 5D. It is an awesome underwater camera. I loved the Aquatica as well. Easy to set-up. I had no problems with it. I serviced it whenever Backscatter thought I should. I have used some of the images to print as big as 35"x40" and can not tell the difference from an 8x12.
    Jody
    PS Here is what I used with the system which is NOT for sale, but gives you an idea of what else you might want. Prices were guessed at in June, some may have come down in price.
    Accessories:
    MacroMate Flip Lens $549.00 ($588.80 w/tax)
    Hartengerger Nano Light $499.00 Focus Light
    Ultralight Adapter for Nano $22.95
    Lenses:
    100mm f/2.8L Macro Lens $599.99
    Tameron 1.4X Teleconverter $189.00
    Kenko 2X Teleconverter? ~ $250.00
    16-35mm Type 2 f/2.8L Lens $1599.00
    15mm Fisheye f/2.8L Lens $679.00
    16-35mm 2x Diopter $90.00
    16-35mm 4x Diopter 77mm $92.00
    Sigma 50mm
    Styx Arm floats and flat port float
    Edited by jodyelliott
