Proper diopter for Nikon 17-35mm
Started by Bentoni ·
  1. I am rebuilding my system and I'll be using a Nikon 17-35mm behind a Sea&Sea fisheye dome port. Should I use a diopter with this lens? If so, which one provides the best results? ...+2, +4? I'd love to hear from anyone who has used this combination. Thanks in advance.
    Bentoni
  2. I am rebuilding my system and I'll be using a Nikon 17-35mm behind a Sea&Sea fisheye dome port. Should I use a diopter with this lens? If so, which one provides the best results? ...+2, +4? I'd love to hear from anyone who has used this combination. Thanks in advance.
    Bentoni
    Hi Bentoni,
    I have used the Hoya +2 diopter with very good results but I have not tried the +3 or +4 yet..
    // Alex
  3. The +2, +3 and +4 will all work. +2 should work most of the time especially for wider scenes. For closer scenes, the +4 may be beneficial.
  4. The +2, +3 and +4 will all work. +2 should work most of the time especially for wider scenes. For closer scenes, the +4 may be beneficial.
    I was using a Hoya +2 & +4 and when I told Ryan I was using Hoya he told me I really should invest in a real dioper. I bought a B & W +2 from him for the 17-35 and he was proved absolutely correct, All diopters are not made equal. Anyone who doesn't believe me, I'll be happy to sell you a slightly used Hoya Diopter kit (+1, +2. +4) cheap, cheap, cheap!
  5. The +2, +3 and +4 will all work. +2 should work most of the time especially for wider scenes. For closer scenes, the +4 may be beneficial.
    hi all,
    sorry to ask another thing,
    so, if i use a macro lens (like 105mm VR Nikkor) should i use a diopter +4, and if i use a zoom lens, (like 16-85mm VR Nikkor) shoulf use diopter +2?
    thank you
    Rui
  6. I was using a Hoya +2 & +4 and when I told Ryan I was using Hoya he told me I really should invest in a real dioper. I bought a B & W +2 from him for the 17-35 and he was proved absolutely correct, All diopters are not made equal. Anyone who doesn't believe me, I'll be happy to sell you a slightly used Hoya Diopter kit (+1, +2. +4) cheap, cheap, cheap!
    Sorry, my bad. I am also using the B+W. I belive you that the hoya is bad :)
    // Alex
  7. ... using the B+W...
    // Alex
    I have heard all sorts of things about remarkable Canon close-up lenses, with achromatic doublets, but have always found B+W dioptres to be perfectly acceptable.
    Nikon 17-55mm, +3D:
    Re-sized, image as shot, taken 48 hours ago, temperature 4 Celsius, 2m visibility, 20cm fish.
    Tim
    :unsure:
