Surf Housing & Canon 1D Mark II N
Started by Phil Colla ·
  1. Here is YOUR surf housing rig: a Del Mar Housing Projects custom housing, fits the following Canon bodies: 1DsII, 1DII, 1DIIn. May also fit 1DsIII and 1DIII bodies although I have not tried that. Includes dome port which I use for the 15mm fisheye for barrel and tube shots. Also includes two flat ports for 17-40 and 70-200 f/2.8 lenses. Note that this is a surf housing (above water) not a conventional underwater (diving) housing, i.e., it can take a pummeling in big surf and keep your camera safe and dry, and you can easily fire off a sequence at arm's length as that big wave closes over you, but in dedicated underwater (below surface) it is not as sharp as a conventional diving housing.
    Here are some barrel shots taken with a 15mm fisheye and 70-200 f/2.8 with this rig:
    http://www.oceanlight.com/lightbox.php?ss=...404,19405,19553
    Here are some topside shots taken just last week with the Canon 1D II N body, topside, to illustrate its use in topside and sports photography. 8 frames per second!
    http://www.oceanlight.com/1diin/
    Housing with all ports and Canon 1D II N body with 2 batteries and charger: $2300.
    Just the Canon 1D II N body with 2 batteries and charger: $1500.
    Phil
  2. Phil,
    Do you still have this? I'm a nikon shooter but I'm temted to cross over just for water housing stuff. Let me know.
    Scott
    Phil
  3. Here is YOUR surf housing rig: a Del Mar Housing Projects custom housing, fits the following Canon bodies: 1DsII, 1DII, 1DIIn. May also fit 1DsIII and 1DIII bodies although I have not tried that. Includes dome port which I use for the 15mm fisheye for barrel and tube shots. Also includes two flat ports for 17-40 and 70-200 f/2.8 lenses. Note that this is a surf housing (above water) not a conventional underwater (diving) housing, i.e., it can take a pummeling in big surf and keep your camera safe and dry, and you can easily fire off a sequence at arm's length as that big wave closes over you, but in dedicated underwater (below surface) it is not as sharp as a conventional diving housing.
    Phil
    hey,
    i am looking for a surf housing and a new cam.
    this seems at a good price.
    is it still for sale and is there a price that i am able to pay for your lens as wel maybe?
    cheers
