Hi,
I am also researching ring lights for a possible purchase. Are there now any units other than the Athena ARF10 and the Inon? I agree the Athena unit is a little underpowered and slow (based on specs alone, as I do not own one). So I wonder about the potential to use the ring from the Athena ARF10 unit, but modify another more powerful strobe, such as an Iklelite DS51, to supply the power. (For example, remove flash tube from DS51 and connect the wires feeding the flash tube to the ring via compatible cable.) Then it could also operate in TTL with compatible digital cameras.
UW3D
I'm interested in adding a ring flash to my kit (Canon 450D + Hugyfot housing + Hugyfot port FLP-6.100 + Canon 60 F2.8 macro USM + Inon D2000 type 2 strobe); to the best of my understanding the only ring flash models available on the consumer market are INON Z22 and ATHENA ARF10. Does anyone have any experience with these units ??? The INON as a 22 guide number .... Does anyone now the ATHENA guide number ??? I assume it should be lower considering the price gap between the two units (ATHENA € 700 - INON € 950). I doubt both units could be fixed to my flat port, so I'll have to figure out an arm system to position them in front of the port.
Would the ring flash set up be an advantage compared to a double strobe set up ??? Would it be a waste of money and I should stay with my single INON D2000 strobe positioned just above my port ??? Should I add a second INON strobe (D2000 or Z240) and positon both strobes to the side of my port ???
Any input or advice is very much welcome !!!!
Francesco
Hi,
UW3D
Hi Francesco,
I use the Athena ring-flash for about 85% of my macro work and at distances of about two inches (50 mm) to about eighteen inches (450 mm). The lenses I use range from 70 to 200 mm in 35 mm terms and run from 1:1 to 2:1, I also use wet diopters. I shoot at ISO 100 and from F/11 to F/32 without exposure issues. The upsides to the Athena ring-flash are its small size, the fact that it can be made to work with about any macro port and the fact that you can control power by turing a dial up and down through the full power range, (unlike the Inon Z-22 which has three power settings). Downsides are that it only works in manual (not a large problem), it is not as robust as the Inon Z-22 and it only uses two AA batteries, unlike the Inon which takes four batteries and has faster recycle times. I also use two Inon Z-240 strobes for the rest of my macro. Its clear that the Inon Z-22 ring-flash was designed for film photographers and needs to be updated. I hope that at some point Inon will redesign their ring-flash to work in S-TTL and reduce its size as they have with the smaller S-2000 strobes which were shown at DEMA.
Phil Rudin
