Nikonos SB-104
Started by Daniel P ·
Nikonos SB-104
  1. Hi
    I've bought a Nikonos SB-104 strobe without
    the original battery pack,and I need to buy a new battery pack. Does anyone you know if I can replace the original NiCD battery with a Nimh battery pack or maybe Li-ion battery pack. Does anyone have any experience from this.
    / Daniel
  2. Hi
    / Daniel
    My battery pack died so I replaced the cells inside the casing with higher capacity NiCd cells after reading the following thread. They have also used NiMh.
    http://wetpixel.com/forums/index.php?showt...art=#entry50264
  3. My battery pack died so I replaced the cells inside the casing with higher capacity NiCd cells after reading the following thread. They have also used NiMh.
    thanks
    What capacity did you choose on your NiCd cells, and what recycling time do you have on a full flash?
    /D
