Problem with D200
Started by deepsea ·
  • 11Posts
  • 11Replies
Problem with D200
  1. One of my D200 bodies seems to be having battery contact problems, I have cleaned all the batteries and contact but it still has not solved the problem. When I put the battery in it lasts for a few photos (roughly 10 frames) and then just flashes the low battery indicator at me and thats it for my dive.
    I have put my batteries over into my other D200 to check them and they are okay and shooting fine. The camera has never been dropped or damaged, it was working fine and then one day it just started having problems.
    I am off to Hawaii in 3 weeks and want to know if there is any good reputable shops that may be able to fix it for me quickly, or if anyone has any ideas from here about what the problem might be I would be grateful.
    Many thanks
    Karen
  2. One of my D200 bodies seems to be having battery contact problems, I have cleaned all the batteries and contact but it still has not solved the problem. When I put the battery in it lasts for a few photos (roughly 10 frames) and then just flashes the low battery indicator at me and thats it for my dive.
    Many thanks
    Karen
    It happened to me with D80. I google for problem and found solution that does not make sence but it works.
    Clean contacts between body and lens! It worked for my D80 so far. I know .... hard to belive.
    Grega
  3. It happened to me with D80. I google for problem and found solution that does not make sence but it works.
    Grega
    Thanks sounds strange but will give it a try, fingers crossed
  4. Dead battery syndrome.
    Make sure you have the latest firmware upgrade. Gets rid of the problem.
  5. Dead battery syndrome.
    Thanks will double check my update
  6. I had the same issue, and my camera had the latest firmware. It had never done well with batteries, however from Day one. Died on the last day of a trip. I thought it was the batteries. I had to fight Nikon, as the problem did not improve after several six week waits for service. Luckily mine was till under warranty, and after being very adamant, they replaced the body. The new one has been fine.
    Hope you find out what the problem is, and cure it.
    Marli
  7. Hi
    Many thanks for your comments Marli, mine is sadly out of warranty as I have had it for 2 years, I like you have the latest Firmware, am still trying all the contacts. It has worked perfectly for all the time I have had it and then one day just takes a crap on me.
    Fingers crossed, have not given up hope yet.
    Karen
  8. Are you using original or 3rd party batteries?
  9. Hi Maarten
    I am using original Nikon batteries, I have three and have tried each one with the sam result of failure in one body and work fine in the other body. I am hoping that cleaning the contacts will work otherwise I will take it to Hawaii and see if someone there can look at it.
    Any suggestions are welcome though?
    Karen
  10. Unfortunately, there does not seem to be an authorized repair facility in Hawaii. Here is what is on the Nikon USA website:
    West of the Mississippi River:
    Nikon Inc. Photo & Digital Service
    Nikon Inc. Factory Service
    841 Apollo Street, Suite 100
    El Segundo, CA 90245-4721
    (310) 414-8107
    Perhaps a call can lead you in the right direction. Also, maybe a post on the Nikonians website forums will get a response re: a recommended camera repair facility.
    Here's another listing, but I don't know if it is current:
    Photo Tech Servicenter
    1413 South King Street Suite 201
    Honolulu, HI 96814 Map
    1-808-952-6161
    This camera repair shop features camera service and repairs.
    Good luck!
    Marli
    Edited by scubamarli
  11. Unfortunately, there does not seem to be an authorized repair facility in Hawaii. Here is what is on the Nikon USA website:
    (310) 414-8107
    1-808-952-6161
    Good luck!
    Marli
    Thanks Marli, I had the smae info, I have a guy coming here on Thursday for an OW course who is a Nikon rep in UK, so hopefully he might be able to shed some light......
    Hope you are getting some diving in 2009,
    Karen
