Wide-angle behind flatport
Started by Maarten_NL ·
  1. I test fitted a 17-50mm Tamron lens behind a flatport designed for 60mm yesterday. ok, there is no room for zooming but for the time being I have a 2nd lens that I can use for semi-wide-angle (17mm x1.6 crop = 27.2mm) unit I saved up for a dome.
    What kind of distortion can I expect, or is it neglibe at this no-so-wide angle?
  2. Maarten,
    behind a dome that would indeed be similar to a 27,3 lens, but behind a flat port, the glass/water interface will work like another 1,33 factor (just like your mask). That means that your lens will be more like a 35 mm.
    the curve of a dome helps preserve the original field of view. check this wetpixel article for a starter on dome port theory.
    http://wetpixel.com/i.php/full/dome-theory/
    Gerard
  3. Ok, thanks for the pointer ;)
    35mm compared to the macro is still a lot wider.. going to test it a bit in the pool next week.
    I still have 3 months until the Cuttlefish breeding season, enough time to get hold of a nice dome.
  4. You may have a problem with vignetting, since your 60mm port is not designed for a WA lens.
  5. There is no sign of vignetting above water.. and since the lens is at 2mm behind the glass I don't expect it to show vignetting under water.
  6. Maarten, behind a dome that would indeed be similar to a 27,3 lens, but behind a flat port, the glass/water interface will work like another 1,33 factor (just like your mask). That means that your lens will be more like a 35 mm. The curve of a dome helps preserve the original field of view. check this wetpixel article for a starter on dome port theory. http://wetpixel.com/i.php/full/dome-theory/
    Gerard
    Hi Gerard and anyone else,
    I am as far as one can get from a mathematician myself, but is it 1.33 or 1.25 the change in the focal distance? I saw 1.25 on the Successful Underwater Photography book, but I would lean (intuitively) at the 1.33. Anyone?
    Edited:
    I guess I found the end of the confusion:
    Excerpt from the book: Scientific Photography and Applied Imaging By Sidney F. Ray p512
    For lenses placed closely to a flat port underwater:
    "... the object distance decreases by 25%, magnification increases by 33%.
    Consequently, with a flat port, a lens used underwater has it's EFL (effective focal length) increased by 33% approximately...
    ... In addition the port introduces chromatic aberration, astigmatism and distortion"
    Nice uh? So a 105mm with 1:1 magnification gets 1:1.33 underwater?
    Edited by Mariozi
  7. You also have to worry about chromatic aberrations due to the prismatic effects of the flat port. Possibly other lenticular aberrations as well. These are more limited with a dome port. A macro lens doesn't this problem to a much greater degree because the lens only focuses on the center of the flat port.
    I use the Tokina 35 mm macro lens (dx) behind a dome port. Seems to give better image quality than using a flat port. I know people who swear that even the 60 mm macro benefits from a dome port.
