settings D90 Nikon
Started by chrispak1962 ·
settings D90 Nikon
  1. What settings do you use for you D90 from Nikon for underwater photography?
    i use the 50mm lens from Sigma.
    Chris
  2. What settings do you use for you D90 from Nikon for underwater photography?
    Chris
    Hi, Chris and welcome to Wetpixel!
    That's a pretty open-ended question ... what kind of photography are you doing underwater? What is the source of light? Etc ... All of these kinds of things would be helpful in trying to help you get the most out of your stuff and time underwater ...
  3. [
    Edited by chrispak1962
  4. Well i use the nikon Sb 105 and its mostly close range. So from 20 cm till 2 meters.
    I also have a focus light.
  5. Well i use the nikon Sb 105 and its mostly close range. So from 20 cm till 2 meters.
    Hi Chris, and welcome.
    Another couple of questions...
    Are you a complete newbie to UW photography or just new to digital/SLR/housings?
    The SB105 makes me think you may have been using Nikonos previously?
  6. Hi Chris, and welcome.
  7. Well i used a Hugyfot house with a Nikon F70. Want to keep the SB 105 for its good enough.
    www.onderwaterfoto.wolweb.nl
  8. Well i used a Hugyfot house with a Nikon F70. Want to keep the SB 105 for its good enough.
    Nice website. Looks like you're not a total newcomer when it comes to underwater photography!
    When you were shooting the F70, did you have TTL-flash control or were you shooting fully-manual? What housing and port do you have for your D90? Do you have TTL capabilities with the new setup?
    How familiar are you with the differences between a D90 (a "cropped" sensor DSLR) and your older 35mm film cameras?
