SEA & SEA YS-110, accessories
Started by machas ·
  • 9Posts
  • 9Replies
  1. DX-D200 Set up - will sell as a package or individually.
    INCLUDES:
    1 SEA & SEA DX 200 housing
    2 SEA & SEA YS 110 Strobes
    1 SEA & SEA TTL Converter
    2 SEA & SEA 5 pin connectors
    1 SEA & SEA Standard Flat Port
    1 SEA & SEA Optical Dome Port (GLASS – not acrylic)
    1 Sea & Sea Nikon 12-24 Zoom Gear
    1 Sea & Sea Nikon 18-70 Zoom Gear
    2 SEA & SEA Basic Arm VI set (both sets new in box)
    Purchased new in March ’07 – equipment has been on 10 dive trips – well cared for & maintained and works perfectly. Housing and strobes have a few cosmetic imperfections as illustrated in the photos, and the rubber viewfinder cover is missing from the housing. The setup functions perfectly. A full set of images can be viewed at: See the Pictures
    Detailed product info can be found by accessing the User Manuals @ seaandsea.com.
    HOUSING:
    Main features of the DX-D200 housing:
    The optional TTL converter for Nikon cameras enables automatic TTL flash adjustment. (Included in the set – description follows)
    The tough aluminum body is compact, very close in size to the camera’s dimensions, and is easy to hold stable underwater.
    The front and rear halves of the body are both made of a corrosion-resistant aluminum alloy improved and enhanced for better rigidity and handling.
    The pickup viewfinder,a key element for digital SLR photography, magnifies 0.66x for clearer framing.
    The new shutter lever is sensitive and provides clear feedback for the finger.
    The housing is compatible with NX lens ports and other NX accessories.
    The housing controls provide most of the Nikon D200 features underwater.
    * The quick shoe makes it easy to insert and remove the camera.
    * The port lock mechanism prevents the port from coming free.
    * The locking latches prevent accidental housing opening.
    * The leak sensor tells you immediately if water gets into the housing.
    ASKING: $1200.00
    2 SEA & SEA YS 110 Strobes:
    The YS-110 strobe is packed with ground-breaking features designed for the new age of digital photography. When it’s connected via a fiber-optic cable to a compact digital camera with TTL metering, the YS-110 strobe offers DS-TTL (Digital Slave Through-The-Lens) light adjustment. DS-TTL follows the camera’s TTL-adjusted flash for automatically accurate flash photography. You can use two YS-110 strobes for creative effects with subtle light balance. For example, you can set one strobe to DS-TTL mode and the second strobe to manual mode. The YS-110’s mode compensation function provides a light level control dial for just the right balance of light.
    The YS-110 also provides full manual control that sets flash intensity that is independent of the camera. The 13-step manual control provides a finely graded variety of light settings up to a powerful maximum setting of guide number 22. Three xenon tubes positioned in the strobe provide a flat balance all the way across a circular beam angle of 105° (with diffuser), with even and consistent light that will satisfy even finicky professionals.
    The YS-110 contains a high-luminosity white LED target light located in the center of its front face. The target light turns on with a convenient button press on the strobe’s rear panel, and turns off automatically when the YS-110 flashes. You can connect the strobe to digital SLR cameras and film cameras using the same cables that connect conventional YS-series strobes. You can also connect the strobe to compact digital cameras using a fiber-optic cable.
    The YS-110 is a versatile strobe designed for almost any use.
    The strobes are used and show cosmetic wear - they function perfectly.
    ASKING: $300.00 PER STROBE
    SEA & SEA TTL Converter III:
    This converter is equipped with a built-in TTL PCB that connects a Nikon digital SLR with SEA & SEA YS-Series strobes and uses the camera's TTL flash adjustment to control the amount of light put out by the strobe.
    The converter allows quick switching underwater between TTL mode and manual mode from outside the camera. You can use the TTL correction dial after checking the results of a shot in the LCD monitor to adjust the amount of strobe light for the next shot.
    Because the converter comes with two separate strobe connectors, you can use advanced automatic TTL flash adjustment with two strobes.
    Specifications:
    Construction: Main body: Polycarbonate, Mounting plate: Corrosion-resistant aluminum alloy
    Controls TTL mode / manual switch / TTL light adjustment dial (from +1 to -1 in 1/3 increments)
    Battery CR2 lithium battery (included)
    Strobe-side connector 5-pin Sync Cord/N, Camera-side connector: Type-N sync cord (5-pin connector)
    Depth rating 60m / 200ft
    Dimensions: (WxHxD): 68x90x75mm / 2.8x3.6x3inch
    Weight Approx. 320g / 11.2oz (including CR2 battery)
    Compatible housings DX-S5Pro, DX-D200, DX-D80, DX-D70/70s (with customized connector), DX-D50 (with customized connector)
    Light adjustment recognition Nikon method (TTL flash adjustment)
    ASKING: $350.00
    2 SEA & SEA 5 PIN CONNECTORS:
    Sea & Sea 5 pin TTL sync cords are used to connect a Nikon camera or a housing with a Nikon style bulkhead to one YS series strobes.
    INCLUDED WITH PACKAGE ONLY - NOT FOR INDIVIDUAL SALE
    This AR multi-coated glass dome port is ideal for wide-angle photography with a digital single-lens-reflex camera. It comes with a port case and a dome port cover.
    Features:
    * Greatly reduces peripheral aberration (distortion) so images are clear from corner to corner.
    * Efficient light transmission sharpens images.
    * Greatly reduces flare when shooting into light.
    * Made of glass so it sheds water droplets, excellent for clear over/under shots (half above water, half below).
    * Aged deterioration resistant than an acrylic dome port.
    • Dimensions (DIAxD) : 181x78mm / 7.2x3.1inch
    • Weight : Approx. 950g / 33.2oz
    • Construction : Corrosion-resistant aluminum alloy (anodized, anti-reflection coating on the inner surface) - Dome : Optical glass BK7 (AR multi-coated)
    • Compatible models : NX and DX housings for SLR cameras except NX-100PRO, NX-5PRO, DX-D100 and DX-S2Pro
    Includes
    * Optical Dome Port
    * Neoprene Dome Cover
    * Soft Storage Case for Dome Port
    * Rear Port Cover
    ASKING: $900.00
    SEA & SEA STANDARD FLAT PORT
    Housing Port for all NX and DX series
    For use with Nikon 60mm and 105mm
    Dimensions (DIAxD): 135x56.5mm / 5.4x2.3inch
    Weight: Approx. 345g / 12.1oz
    Construction: Corrosion-resistant aluminum alloy (alumite coating)
    Includes Optional front port cover
    ASKING: $200.00
    SEA & SEA Nikon 12-24 Zoom Gear
    This is the zoom gear to use with the Nikkor AF-S DX 12-24mm f/4G lens.
    You would use this gear when using the lens with the following ports:
    * NX Fisheye Dome Port (56401)
    * NX Compact Dome Port (56601) with the SX Extension Ring (50261)
    * CX Compact Dome Port (46100) with the NX Compact Macro Port Base (56201)
    * Compact Wide Port (56280) with the NX Compact Macro Port Base (56201)
    ASKING: $100.00
    SEA & SEA Nikon 18-70 Zoom Gear
    This Sea & Sea zoom gear is used with the Nikkor AF-S DX 18-70mm lens. You would use this gear when using the lens in the DX-D70 housing along with the 30103 compact wide port L and the 56201 NX compact macro port base.
    ASKING: $100.00
    2 SEA & SEA Basic Arm VI sets (both new in box)
    This multiple-type arm stay set has been updated to allow greater tightening force. Plastic resin construction prevents electric corrosion and makes it more durable. The new ball joint design allows firmer tightening and smoother loosening, and tighter grip at each joint makes arm position more secure.
    [Construction] Plastic resin reinforced with glass fiber
    ASKING: $150.00 per set
    Current Retail Pricing from online shops – B&H/Leisure Pro/Adorama)
    SEA & SEA DX 200 housing (1400.00 - 2495.00)
    2 SEA & SEA YS 110 Strobes (450.00 - 525.00 each)
    SEA & SEA TTL Converter (649.00)
    2 SEA & SEA 5 pin connectors (69.00 - 109.00 each)
    SEA & SEA Standard Flat Port (289.95)
    SEA & SEA Optical Dome Port (1249.00 - 1325.00)
    Sea & Sea Nikon 12-24 Zoom Gear (172.95 new)
    Sea & Sea Nikon 18-70 Zoom Gear (174.95 new)
    SEA & SEA Basic Arm VI set s(155.00 - 249.00 )
    TOTAL PACKAGE VALUE – 4500.00-6500.00
    ASKING for the PACKAGE: 3750.00.
    Please email me: with any questions. housingfront.jpg
    Edited by machas
  2. Please note a correction - there is a typo in the Ad - the TTL Converter is a The SEA & SEA TTL Converter II as pictured (not the III).
  3. UPDATE: The full setup is no longer available - Available components are as follows:
    1 SEA & SEA DX D200 housing
    2 SEA & SEA YS 110 Strobes -used (Product # 03106)
    1 SEA & SEA YS 110 Strobe -new in box (Product # 03106)
    1 SEA & SEA TTL Converter II (Product # 50108)
    3 SEA & SEA Basic Arm VI set (both sets new in box) (Product # 22106)
    HOUSING:
    ASKING: $1200.00
    2 SEA & SEA YS 110 Strobes - USED, 1 NEW:
    ASKING: $300.00 PER USED STROBE
    ASKING: $425.00 FOR NEW STROBE
    SEA & SEA TTL Converter II:
    Specifications:
    ASKING: $350.00
    ASKING: $100.00
    3 SEA & SEA Basic Arm VI sets (all 3 are new in box)
    SEA & SEA Basic Arm VII sets(155.00 - 249.00 )
    Edited by machas
  4. Sent you a message
    Tony
  5. UPDATE: the TTL Converter is no longer available.
    Available pieces are:
    3 SEA & SEA Basic Arm VI set (all sets new in box) (Product # 22106)
  6. UPDATE: the TTL Converter is no longer available.
    Hi,
    I am interested in the 18-70 Zoom Gear? Would you ship to Brazil? Do you accept Paypal?
    Thanks a lot
    Savio
  7. UPDATE: 2.14.09
    3 SEA & SEA Basic Arm VI sets (all sets new in box) (Product # 22106)
  8. UPDATE: 2.15.09
  9. Hi,
    Thanks a lot
    Savio
    I sent you a private message.
    Savio
