replace Oly 5050
Started by widiver ·
replace Oly 5050
  1. Hi all
    It might be time to replace my oly 5050 with olympus housing. I currently have a set of ultralight arms, an inon ucl-165-m67 lens, and a inon d-180 strobe. I would like to be able to use all of those parts with my next setup. I have been doing some research and it looks like the canon G10 keeps coming up as a winner. I noticed that the FIX G10 housing will accomodate the strobe and you can buy an adapter for the close up lens. Is there an adapter for the close up lens that can be used with the canon housing?
    What about other cameras and housings that will work with the strobe and closeup lens?
    thanks
    John
  2. I am also upgrading from my Oly 5050 & I bought the Panasonic LX3 for the F.2.0 bright Leica lens. Both my wide angle, macro lens & Sea&Sea YS55 strobe are compatible with the 10Bar housing. You might want to check out this thread:- http://wetpixel.com/forums/index.php?showt...=27978&st=0
    Hi all
    thanks
    John
