Sea and Sea TTL Converter Socket Circuit Diagram
Started by Scuba_SI ·
  1. Can anyone get their hands on a circuit diagram for the converter socket on the new sea and sea housings (nikon)? I bought the newest TTL Converter and it works on a S&S D300 housing when connected o the converter socket, but does not work on my Nexus D200 housing, so i figure i need to find out what is under that little plate in the top of the D300 housing.
    Simon
  2. Not working with Nexus may be related to the hot shoe adapter circuit within the housing. At least this was a problem with the original TTL converter & my D70 housing. S&S converters don't even work with all S&&S housings.
  3. Hi,
    You should have NCC connector on housing, not NCC V.2 or V.4.
    and you can get it from here;
    http://reefphoto.com/index.php?main_page=p...e469c417158d31e
    also, depends on model of TTL converter you have, you may 'melt' your houisng.
    (you can research old thread with my ID or 'melt')
    S&S is saying do not use it with other than S&S housing.
    Sam
    Edited by shchae
  4. Thanks for the feedback.
    The thing i dont understand is that i had the 2008 model converter on the housing a few weeks back and it worked fine.
    I'll try and source one of those parts i guess. :P
