lightroom question
Started by modiver ·
lightroom question
  1. How do you keep lightroom from starting up whenever you hook up anything with a picture on it.
    I love lightroom but it keeps starting on its own all the time. I've looked in preferences but can't find where to set it so that I start it when I want it.
    Thanks in advance for any comments
  2. How do you keep lightroom from starting up whenever you hook up anything with a picture on it.
    Edit ... Preferences ... Import ... checkbox: "show import dialog when memory card is detected"
    At least on Windows.
  3. Edit ... Preferences ... Import ... checkbox: "show import dialog when memory card is detected"
    Thanks, but...
    I have that checked. But even when I plug in my phone, Lightroom starts up. There should be a way to keep it from starting up unless you select it.
    Edited by modiver
  4. Thanks, but...
    Uncheck it and see if it helps.
  5. I think you may need to change your Windows AutoPlay settings for your Camera.
    From memory, if you plug in your camera, then, in windows explorer, right-click on the Camera icon and select Properties. There should be an AutoPlay tab where you can change the default behaviour.
    If that doesn't work then on XP i think you can use the TweakUI app in the free Microsoft PowerToys collection. When you run it take a look underneath the My Computer/AutoPlay section.
    jon
