Subtronic, maker of high end strobes, announced their new Video light at Boot in Dusseldorf. This new video light uses LED diodes laid in a 16:9 pattern and the beam covers 110° in the rectangular shape vs the traditional round shape. Most exciting of all is the CRI is claimed at 96, the highest available LED diode available. If these claims are true, the biggest stumbling block for LED has just been removed with the release of this product.
The lamp head is 500g(1.1lbs) and the Akkutank 7.2Ah LiMn (they use Li Mg (which is magnesium is approx 1kg (2.21 lbs). A dual head lamp and battery will weigh approx 2kg (4.42lbs). There is very little information from Subtronic (as usual) but if this is the same LED diode that produces 55lm/W then it should have over 2300 lumens per head (considering operational inefficiencies). This would make it the highest output LED video light announced.
It is also competitively priced as it costs €1407.56 (MSRP, no VAT) or just under US$2000 for 2 lamp heads, battery and charger.
Burn times are assumed to be 75mins for one head, 35 for 2 heads, power is variable from 1/4,1/2,3/4,full.
Fathom what you can from Subtronic's own website:
A bit of warning: from research in the WP archives, Subtronic does have the reputation of taking a long time for service of their products, especially for those outside of Germany. If their product does produce what is advertised, then hopefully their innovation also crosses over to their service dept.
