Sigma 10-20?
Started by ripli ·
Sigma 10-20?
  1. Did someone tested the sigma 10-20 underwater? do i need a diopter to use it? wich one?
  2. I have used it.
    My setup is:
    D300 + Sea&Sea's MDX-D300
    ER40 + Sea&Sea Optical Dome Port (glass).
    No diopter needed.
    Sea&Sea recommends the SX Extension Ring... I have it, but found the lens performing better (specially corners) with the ER40 which is a 40mm extension ring.
    My Optical Dome Port is the equivalent to the Compact Dome Port (the small one in acrylic).
    Good luck
  3. Did someone tested the sigma 10-20 underwater? do i need a diopter to use it? wich one?
    That will depend on your dome size and extension.
    With the nikon d200 in Seacam with Superdome (edit) and 35mm extension (edit) I don't use a dioptre.
    Edited by photovan — added the extension reference
  4. I use it in a Hugyfot D200 housing with the Hugyfot FE domeport. They reccomend the smallest extension. I tried it without extension and found that set-up to be sharp across the image as well. No dioptre. Speculation from my side: I think this lens may have some more barrel distortion than the other wide rectiliner zoom lenses, hence it works a little bit better behind a dome port.
    cheers
    Edited by Christian K
  5. That will depend on your dome size and extension.
    And I should have said that I am very happy with the results.
  6. Did someone tested the sigma 10-20 underwater? do i need a diopter to use it? wich one?
    Thanks :D
    I tested the Sigma 10-20 with the Olympus 6'' and Inon 6" Domeport. A diopter is not needed.
    But with this Domes the lens performed bad. The center ist good, but the corners aren't sharp.
    Have anyone expierence with the Ikelite 8" Domeport and the Sigma 10-20?
  7. Have anyone expierence with the Ikelite 8" Domeport and the Sigma 10-20?
    I use this with Ikelite 8" and the #5510.58 4cm extension and find optically it works okay (but not done any fancy sharpness testing).
    However the lens has a very big barrel so is a very tight squeeze and I had to modifiy the clamping arangement.
    Check out :-
    http://www.images-underwater.net/Modified_zoom_clamp.html
    Richard B.
    Edited by rbailey
  8. I just added a pool pic with it on my site (at the signature below) on the News page, it performs really nice in my S&S setup.
    BTW: No diopter.
    Edited by Mariozi
