I have had the privilege of spending the last couple of days with one of the Gates Deep Red housings and a Red One with an 18-50 lens. Yesterday I spent a good 4 hours with John down at Gates going through the set up process, and today we did some in pool testing and trimming of the buoyancy. All seems to be dialed out nicely now and ready for tomorrow where we will be taking it out Catalina to do some cold water tests as well. I have some video clips shot on the EX1 of our buoyancy tests from today...and will be shooting the same in the ocean tomorrow. Will report back with more details on the housing.
Here are some initial thoughts after a few hours in the pool today (more details to follow tomorrow).
1. Housing is very manageable in size. For anyone that has used a larger housing from Gates (Z1U, EX1, etc) you will find the housing to be somewhat comparable in the handling (side by side pics coming this weekend). The Red is noticeably wider than the other housings, but length was not significantly different. The ergonomics and controls that John has engineered are fantastic. The large control wheels are very easy to use. The housing requires a lot of weight (mounted both inside and outside of the housing) in order to achieve slightly negative buoyancy.
2. The Red LCD is amazing and sharp and the housing built by Gates for it allows access to the controls on the top, thus providing use of two more assignable controls. Id pay for a monitor like this to use with my EX1 it was so amazing!
3. Set up is much more intuitive than any housing I have ever played with. To do a thorough set up, its a solid hour and a half or more (from camera prep to housing assembly and seal check).
Ill have more details tomorrow night after a day at Catalina. We do not have the rig set up with lights, so its going to be a nice test of the low light capability of the camera itself.
