Best shark / wild dolphin lens for Canon rig?
Started by Steve Williams ·
  1. Folks,
    I'm headed off to join in the fun on the Shearwater in a few weeks and I'm at a loss as to what lenses to bring along. I see that Alex is heading there in a couple of weeks too, so hopefully this will be helpful to a few of us. I've read the comparison of the Tokinas and I enjoyed Mike's article on diving with sharks. I still don't know which lens setup will be the best for image quality with the 40D.
    The shots I'm really unsure about are the wild dolphins. I would really appreciate your advise. I have been considering these to go along with my Tokina 10-17;
    Canon 10-22
    Canon 17-40L
    Tokina 11-16
    Tokina 12-24
    I may never get another shot at swimming with dolphins for 4 days. I'm really hoping I can do this right.
    I appreciate your thoughts,
  2. I would highly recommend the 17-40L, Steve - especially for dolphin shots. First off, it's a great versatile lens that you will end up using often and it's also tack sharp. I switch between that and the 10-17. Especially, with the other lenses you have listed, I don't think you'll see too much a difference in range to warrant getting one of them. I don't have any experience with the other Tokinas, but used to shoot with the Canon 10-22 and sold it off for the Tokina 10-17 and couldn't be happier. Not sure you can do much better for your wide angle arsenal than the 10-17 and 17-40 with a crop sensor.
  3. 17-40L would be the best other option in my mind for the money. It will give you a little different portfolio of images from the 10-17.
    Enjoy!
    Todd
  4. Abernethy uses a 10-17, but then again, he also has a bait box in the other hand. Have a great trip :D
    Just for reference, I use a 17-55mm with a Nikon D70/D300. It requires a diopter in the setup I use. +4 gives best corner sharpness but it won't focus at infinity on the 55mm end. A +3 works over the entire zoom range, but corners are just a bit soft, but not really noticeable unless you look closely. The same might pertain to the 17-40, but not sure since I don't speak Canonese. Just something to check.
    Edited by jcclink
  5. Thanks guys! It's great to get input from the pros. Bryce and Todd both of your websites are wonderous. And Jim I saw you have over 50,000 views on yours, that's pretty cool. I was leaning hard toward the 17-40L but some other folks I asked thought it might be a little to narrow. It's hard to know how close one can get to the dolphins. JC brings up a great point. :D Do you Canon shooters use a +3 or +4 diopter with the 17-40? I plan to use my big fisheye dome and I already have the extention ring S&S recommends.
    Edited by Steve Williams
  6. Steve,
    I've just comeback from a Shearwater trip. I took 17-40mm & 15mm FE lenses for my 5D, and ended up only using the FE! However I can't comment on the dolphins as the only ones we saw were riding the bow wave! The sharks come very close though!
    On previous trips with a cropped sensor I was using a 10-22mm lens which was fine at Tiger Beach but too wide for the hammerheads which were more nervous around us & didn't get close enough.
    Regarding the diopter on the 17-40mm I can tell you I have a +2 only currently, but I am thinking of experimenting with a stronger one at some point!
    Hamish.
