FS: Mint Sea & Sea DX8000G & YS-27DX Digital Camera Sport Package $500 OBO
Started by directorvfx ·
  1. Mint Condition very lightly used. $500.00 or best offer. Email me at directorvfx at gmail.com
    The 8000G captures images using 8.24 million effective pixels that clearly record the details in every frame. This high end compact digital camera processes mass image data at high speed and simultaneously reduces image noise. The 8000G's zoom lens contains nine lens elements in seven groups and employs anoptical 3x zoom that expands to 28mm at full wide angle and captures ample light around its edges. The 8000G camera has a stylish aluminum alloy body that fits comfortably in your hand. The platinum silver coated grip makes the camera easy to hold and shoot. The 8000G camera goes beyond still images it shoots movies! It can capture high quality moving images AVI format, 30 fps underwater, and can shoot until the camera's memory is filled. You can customize the 8000G camera's ADJ button to display parameter settings that you use most often exposure compensation, white balance, ISO, and other functions. You can display a real time histogram on the LCD monitor while you're shooting so you can see the light levels in your image, or display the histogram for images you've already captured. White balance works a little like a color filter. The 8000G offers six white balance modes Auto, Daylight, Overcast, Tungsten Light, Fluorescent Light, and One Push Manual Setting that manually sets the white balance. You can set exposure compensation in fine increments of 1/3 EV, perfect for capturing images with tricky lighting. Exposure compensation ranges from +2.0 EVto 2.0 EV in 1/3 EV increments for fine adjustment. The aperture prioritized exposure mode lets you set the size of the iris opening in the camera's lens. You can use it to control the depth of field. The 8000G supports three types of power supply a high capacity rechargeable battery, AA batteries, and an AC adapter. The rechargeable battery lets you work for extended periods without battery change, and captures about 400 images when it's fully charged.
  2. Bump
  3. are you selling YS - 25DX
