For Sale: Light & Motion Titan D-200 housing, ports, port adapter
Started by photoagent101 ·
  1. Light & Motion Titan D-200 housing: used one trip; you can’t tell that it has been used. It was serviced (some bugs worked out) after this one trip by Light and Motion.
    none of the ports below have been used: (I have two of some of these ports):
    L&M Titan Flat Port: never used
    L&M Titan Ext. Ring
    L&M Fisheye Glass Dome Port (perfect for DX lenses down to the 16mm fisheye)
    L&M ultra wide (weitwinkel) Glass Dome Port (accommodates the Nikon 10.5mm fisheye)
    Sea and Sea adapter ring (has been used a great deal but is in fine condition): allows you to use Sea and Sea ports on this housing.
    This is a complete system for the Titan D200. Ready to go – just add a Nikon D200 and a lens (which I can sell also) along with strobes and arms (of which I have also).
    The housing comes ready to go with EO bulkheads. If you prefer Nikonos V TTL bulkheads, I can put these back in. Note that even with TTL bulkheads, you will not get TTL capability with any underwater housing UNLESS you have put in Ikelite's iTTL system and use Ikelite's newer iTTL strobes. If you buy this D200 housing from the factory with NIkonos V TTL bulkheads, the bulkheads will allow you to use, for example, Sea and Sea strobes and cords -- but you will NOT get TTL capability, only manual flash. Putting Ikelite iTTL wiring inside this and any other housing is possible, but I don't recommend it. I DO recommend Ikelite's iTTL strobes very highly.
    If you are interested, email me at spam@norbertwu.com. Serious inquiries only. I’d like to sell the above as a package and am open to negotiation.
    Edited by segal3
