Sea & Sea TTL converter - strobe compatibility
Started by john70490 ·
  1. Hi all,
    I have recently bought a used Sea & Sea DX-D50 housing and TTL converter (the original version). I have read the long, informative thread on this on this forum from 2007 and have a couple of questions which somebody may be able to answer. According to Sea & Sea's compatibility table, my housing (after modification, which I am having done) is compatible with the TTL converter and YS-90 TTL Duo strobes. I have two YS-90's, so that is no problem. However, I also have two YS-30 TTL Duo (NB not YS-30 II TTL Duo) strobes and wonder if anyone has tested these (in TTL mode) with the TTL converter. If so, did they work? Also, would a YS-30 in slave TTL mode work in combination with a YS-90? The reason I ask these questions is that the YS-30's are small and light, making them the ideal back-up for travel, provided they work with the TTL converter, alone or in slave mode with a YS-90.
    Sea & Sea USA don't know the answers to my questions, so I am grateful for any information anyone can give me.
    Regards,
    John
