Some Wreck & Tech footage from Spring
Started by northseaexplorers ·
  1. Here is some footage we shot on the steamer Spring (Norway) using our new HMI video lights.
    Now all we need is a proper proper camera so if someone want´s to get rid of their PMW-EX1 (or similar) you are more than welcome to get in touch with me. :)
  2. Here is some footage we shot on the steamer Spring (Norway) using our new HMI video lights.
    Really nice. What cam are you working with at the moment ?
  3. Cool! Where do you get your music from?
  4. Really nice. What cam are you working with at the moment ?
    Thanks. We have two, primarily use Sony HDR-HC3e HDV with a not to great W/A adapter and also we have an older Sony DV cam.
    HDV is $#$%! to edit and I usually do something like, HDV1080i@25fps -> Prores 1280x720p@25fps before I even start the edit. Click ok and go make some coffee. A lot. :)
    DV material is much sweeter but a tad bit 2004 so we´re looking to upgrade. :)
    Thanks.
    We´re amateurs so we get to use whatever we want :) , so this is actually something from Hanz Zimmer (sshhh ... don´t tell anyone), but I usually do like everyone else who doesn´t have access to their own symphony orchestra, get something from cc-mixter or similar.
    I´ve also considered getting material from Smartsound, and editing it in Sonicfire but I haven´t yet found any music that´s spot on.
  5. Thanks. We have two, primarily use Sony HDR-HC3e HDV with a not to great W/A adapter and also we have an older Sony DV cam.
    Interesting. A few comments
    1) I notice some "mosquito noise" in your footage. I usually get this (On my FX1) when the gain is ramped up too high. Have you played with fixing the gain control to say 6Db ? With those HMI's you should have plenty of light to make up the difference (as you have plenty of DoF to play with)
    2) I use final cut express which converts HDV to AIC for editing and I can easily edit directly on a 5 yr old Power MAC (Power PC version)
    3) I use smartsound and I get a lot of whining about how bad my music is!!! So I am also looking for alternatives.
    I have some friends that can make soundtracks but it's quite intensive so I reserve that for the more significant videos.
    We have to get together & dive someday :)
  6. Interesting. A few comments
    In english please. Could you dum it down a notch? :P What is DoF and what can it do for me?
    Also, Vimeo did some funky stuff with my initial upload magnifying each clip by 150 - 200%. It´s now re-upped and and the zoom level i back to normal and the noise-to-video ratio has decreased.
    I´ve never used AIC as a have a fairly recent MacBook Pro that can handle Prores and all the benefits (size, rendering, speed) that format/codec gives. The reason it takes so long to convert from HDV1080i to 720p Prores is because of the frame re-sizing (that´s my working theory anyway).
    ´nuff said! ;)
    Sure, were are you based?
  7. In english please. Could you dum it down a notch? :P What is DoF and what can it do for me?
    ´nuff said! ;)
    Apologies on the DoF comment :) I was just saying that your footage looked like the camera had automatically increased gain to compensate for lowlight, which with the HMI's probably is un-necessary.
    On my camera, I fix the gain usually at 0Db sometimes at 6Db. Because the sensors in these cams are relatively small, you get a relatively deep field of view (i.e. a lot of the frame is in focus) even at wide apertures, so you can fix the gain & open up the aperture to get more light in + the HMIs
    I am in los angeles so a bit far :) We were supposed to hit Narvik this year but thats all postponed...
  8. Apologies on the DoF comment :P I was just saying that your footage looked like the camera had automatically increased gain to compensate for lowlight, which with the HMI's probably is un-necessary.
    No worries! I just read your post a bit to quick and didn´t realize until now (aha!) that DoF = depth of field. ;) My bad.
    Edited by northseaexplorers
