housing glue
Started by fuzz ·
housing glue
  1. What kind of adhesive would work best with standard housing material? More specifically, the consumer Olympus or Canon housings.
    Thank you. :)
  2. What kind of adhesive would work best with standard housing material? More specifically, the consumer Olympus or Canon housings.
    Thank you. :)
    Depends a lot on what you need the glue to do. For sealing an edge, then silicone will probably work fine, but you might need to prime the surface first. If you are trying to fix a crack that is under compression, then good luck, you might try underwater epoxy and it might work. what is the problem you are trying to fix?
    Bill
  3. These are considered disposable housings. Better to just buy a new one, or change brands.
