FS: Ikelite Substrbe Ai
Started by rstark ·
  1. I am trying to get rid of an Ikelite Substrobe Ai with TTL sync cord (Nikonos to Ikelite connectors). Everything works and is in great condition.
    $20 + shipping from Los Angeles.
    Pic: http://home.pacbell.net/rstark17/ebay/ikelite/IMG_0127.jpg
    Here are the specs:
    * TTL, Manual, and 1/2 Power Modes
    * Recycle time is less than 4 seconds
    * Measures 4.5" x 7.8" ~ 11.5cm x 20cm
    * Weight is only 3.5 pounds ~ 1.6 kg
    Turning a knob adjusts the angle of coverage from 80 to 95 degrees, allowing optimum coverage for a full range of lenses from 15mm to macro. The adjustable coverage eliminates the need for a diffuser that would reduce the light output by one f / stop.
    The special soft-lite reflector and 4800 degree Kelvin color temperature provide exceptional flesh tones. Built-in modeling light helps in aiming the strobe while illuminating subject's colors.
    The electronics are completely sealed from the battery compartment. The strobe provides approximately 160 flashes from four "D" cell alkaline batteries. Full power recycle time is less than four seconds.
    Edited by rstark
  2. I am trying to get rid of an Ikelite Substrobe Ai with TTL sync cord (Nikonos to Ikelite connectors). Everything works and is in great condition.
    Here are the specs:
  3. I am trying to get rid of an Ikelite Substrobe Ai with TTL sync cord (Nikonos to Ikelite connectors). Everything works and is in great condition.
    Here are the specs:
    i am interested in the ligth
    thank you
  4. i am interested in the ligth
    thank you
    Sure, how can I help you.
  5. Sure, how can I help you.
    i also sent you reply on the A5000 set up
    thanks
