I have a bit of a strange question but hopefully it will be quite easy to answer.
I am arriving in the field next week to work on a project using a Subal D70 housing and FE-2/3 (not sure) dome. In order to do this I essentially have to attach the camera to a complex tripod head. What I need to know is the following two questions. THere may be more later but this is where I am starting.
1) If you place assembled the housing and dome on a table, will it sit flat or does the dome extend below the bottom of the housing?
2) With dome attached, what is the approximate depth of the entire rig from front of dome to back of housing?
I know these are fairly strange questions but as I am building the tripod head I don't have the camera in hand.
Thanks!
Drew
