Sea and Sea MDX-PRO D700
Started by KirkD ·
  1. I was on the Sea and Sea website and saw that they discontinued the housing for the Nikon D700. Since this housing was just launched less than 3 months ago, I guess there must be a story behind this? Anyone know?
    Kirk
  2. Not really, they made a short "pre-reserved" production run on this housing, I guess they only did 100 of them.
    And now they are too busy with the MDX-5D MkII and the separate RDX line.
    The RDX-450D is selling good, but the RDX-D60 is not and I heard a new RDX-D5000 is coming... big mistake IMHO.
    They should have made the MDX-D90 instead months ago!!! I would NOT suggest anything below the D90 on the Nikon line for UWPhoto. mainly due to the lack of AF Motor to drive the Non AF-Ss 10.5mm/2.8 fisheye, the new 60mm/2.8G N micro and the Tokina 10-17mm among others... but they don't ask questions before they do stuff like that, do they?
    They'd better get it right in 2 years when the D90 replacement is due.
  3. This was planned as a limited edition, numbered run of 100. I have #53. :)
    I understand that Ryan at Reef Photo still has one or two because he ordered some extra to account for an early sell-out.
    Linda
  4. This was planned as a limited edition, numbered run of 100. I have #53. :)
    Linda
    Linda,
    What lenses do you use both under and topside?
  5. Linda,
    Not sure if you are only interested in the D700, but I use the D700 as well as a D300 and film cameras underwater and topside. I also use a Canon 5D topside only. I'll try to answer for the digital cameras at least.
    D300:
    • underwater (Tokina 10-17mm, Sigma FE 15mm, Nikon 60mm and 105mm micro plus diopters/teleconverters, etc)
    • topside (I don't have a good rectilinear DX WA lens, so I use my old 24-120mm and 28-105mm zooms as well as 20mm, both micro lenses, lensbaby, and a 70-300mm)
    D700 (the camera is fairly new to me, but this list is also what I use with my 35mm film cameras):
    • underwater (Nikon 17-35mm, 15mm, 20mm, will probably try the 10-17mm with TC, Nikon 60mm and 105mm micro plus diopters/teleconverters, etc)
    • topside (17-35mm, 20mm, 24-120mm, 28-105mm, 70-300mm, both micro lenses, lensbaby)
    5D (all topside):
    • 24-105mm, 100-400mm, 100mm macro
    I don't currently do a lot of birding or much that requires a very long lens for topside work, so I don't have much of this for the Nikons. I did heavily use the Canon 100-400mm with the 5D for the land tours in Galapagos last year.
    Not sure if that answers your question. The list of lenses I use the most is much smaller, has evolved over the years and also depends a bit on the location/subjects.
    Linda
  6. The MDX-D700 sure was a beauty while it lasted. I too wish they would have done more, and certainly wish they would have done a D90 housing!! However the new 5d2 housing is one compact beauty!!
  7. This was planned as a limited edition, numbered run of 100. I have #53. :B):
    Linda
    Hi Linda,
    I am considering S&S MDX-D700 housing but there are not too many hand on review on this housing. Would you be able to share with me your experience with it?
    Many thanks,
    Vince
